MP-803A - Will not Crank from S-1
Maestro
17
Doylestown, PA
Is fuel supply open? - The top of level to the left or right?
The first picture shows the solenoid fully pulled in, it can not move any more to the right, however, it can more to the left when not powered, but it is stopped by the lever
Maestro
17
Doylestown, PA
Will the black knob part of the linkage move freely in the long slot? Because if its tight, and will not slide in the long hole, it wrong,
Yes the knob moves freely in the slot.
What I figured out when the solenoid is not powered it has spring and it should push the top of the lever all the way to left until it hits the hard stop nut. but the lever stops half way. Since the knob is not tight, the only way the lever can move to the right something in the engine governor moves it to the right.
Maestro
17
Doylestown, PA
Is the spring broken, or missing in the rubber "prophylactic" on the piston? Have you made sure the piston slides in and out of the solenoid housing smoothly?
The spring on the solenoid is in working order, I checked at all ready.
I found this https://www.steelsoldiers.com/threads/mep-803a-governor-question.223729/ this could be it since I found one of the gaskets for the metering pumps in the bottom of the unit, but I could not find which one it belong to and they did not appeared they were touched.
Ray70
7,166
West greenwich/RI
Sorry to join late to the party, but I see a couple things that seem odd.
You have already discovered that your fuel lever is not moving correctly and it also sounds like the solenoid is not working correctly either, you should have way more than 1/2" of travel in it.
Also, Your fuel stop lever looks a bit abnormal... kind of home made actually.
It looks as if it was made from a piece of aluminum flat bar and I wonder if the bottom part that is supposed to hit against the lower screw ( at full fuel ) is not quite shaped right, It appears the screw is hitting on that weird corner and the top is supposed to touch against the upper screw when the solenoid is deenergized, ( fuel off ) and that isn't happening either, BUT the real issue here looks to me like your fuel rack is stuck.
Ray70
7,166
West greenwich/RI
I'd say go to the 4th sticky down at the top of this gen. forum, read up on the metering pump / rack cleaning procedure.
Remove the fuel solenoid and remove 1 pump, then you can stick your finger into the hole from the removed metering pump and feel the rack.
Move the fuel lever full travel and see if the rack is moving at all.
If not, remove clean and replace the metering pumps, remembering that leaving 1 pump installed at all times makes rack/ pump pin alignment a little easier for someone unfamiliar with it.
Pay close attention to the notes and tip in the metering pump sticky up above.... they will help keep you hair in place, rather than you ripping it out! ;-)
Maestro
17
Doylestown, PA
@Ray70, as you pointed out the fuel stop/start lever did not look like may others I have see. My unit is a 2010 model and it appears that newer units have a similar lever. I know the metering pumps were replaced, not original no green paint on them and they appear to have a date code of 2023 on them. They were install incorrect, two were not property aligned. I fixed all of that but still have problem, I plan to start a new thread on the specific issue, this thread was about the electrical issues which all have been fixed.
Thanks for your input on this.
Guyfang
27,222
Burgkunstadt, Germany
@Ray70, as you pointed out the fuel stop/start lever did not look like may others I have see. My unit is a 2010 model and it appears that newer units have a similar lever. (You are going to have to show me proof of that. I have never seen one like that. It looks like home brew to me.) I know the metering pumps were replaced, not original no green paint on them and they appear to have a date code of 2023 on them. They were install incorrect, two were not property aligned. I fixed all of that but still have problem, I plan to start a new thread on the specific issue, this thread was about the electrical issues which all have been fixed.
