- 97
- 207
- 33
- Hampton, NH
Someone mentioned my lack of an exhaust system on my last post. It was a valid point. Carbon monoxide is nothing to joke about. I had plumbed an 1 1/4 black iron pipe from the generator, out the side of my enclosure. I removed the pipe when I took off the covers for my testing. I did not have a flexible pipe in it and I was going to fit one. Being an engineer, and one that thinks outside the box, I wondered if there was a better way. What if I could construct a system that didn't need a flexible pipe? In the power plant where I worked, we had many gas fired boilers and other equipment. The big ones had a hard ducted exhaust but the smaller ones used a venturi system. I even had one for my motorhome's generator for when we were parked near other campers and had to run the generator. The principal is simple. Hot gasses introduced into a larger diameter vertical pipe will cause low pressure to draw cool ambient air in thus cooling the pipe and accelerate the flow. I decided to try it. My whole system is made from 4 inch duct from Home Depot. I bought a dryer vent for the termination and a venturi hat for a gas water heater for the intake. I used the 1 1/4 coupling and an 8 inch nipple screwed to the generators muffler. I suspended the ducting to the rafters. The pipe from the generator does not touch the ducting. I ran the generator under load for 1/2 an hour and, although hot, I was still able to rest my hand on the ducting. There was no exhaust smell in the enclosure. I did not have a way to test the airflow with smoke, but using a long stemmed lighter I noticed the air being drawn into the intake side of the duct from almost 6 inches away. Total cost was under $50. I am planning on doing a multi hour run in the next week or so and I will monitor the duct temps where the termination is screwed to the fence. I can easily fabricate an air gap there if needed but I don't think it will get anywhere close to the combustion temp of the wood. (Anywhere for 300 degrees F to 600 degrees).
