WANTED: M-GATOR consultant -having mechanical issue - need a consultant on repair
DaninNM
26
Albuquerque, New Mexico
Anyone? Will pay for reasonable consulting resulting in accurate DIAGNOSIS and REPAIR of a screeching sound when BACKING UP....???. Seems the right side rear wheels are not being driven by the chain drive clutch. No, the rear wheel bearing are fine and turn and do not make noise or resist turning at all. Clutch??? Diff in the clutch housing??? How to repair, most likely cause????
Call help me fix, I'll help your cash flow.
505-269-2056
dougco1
708
Cooperstown NY
505-269-2056
Take it to your nearest JD Dealer repair shop for an assessment.
That will be $50.00 please
Mtnfox62
Bones mill va
505-269-2056
Rear wheels will not engage unless you are in 4 wheel drive. screeching noise is usually the transmission, mine squeals whenever I engage the brake pedal, Check your trans fluid level, replace old fluid, You may need to adjust your brakes (springs on either side of the transmission) or worst case pad replacement within the transmission.
DaninNM
26
My wrench guy found the e-brake misadjusted after removing and inspecting the drive and transmission sections. Seems the e-brake did not release when the brake was put on and then taken off,,,, lot of work done to find the easy fix... LOL
msgjd
4,124
upstate ny
common issue with the commercial gators as well , almost always screech only in reverse if e-brake is sticking .. Gator HPX 2005
