Drivability: REV v A2 trucks
thoner7
238
NE TN
I currently have and love a REV 1165. It’s my only experience driving these trucks. I’m wanting to get a second truck as a work and ranch vehicle. There are a lot more 1123s and 1097s at auction than any 1165s or 1152s, and they sell for less.
To those who own or have driven both - how much difference is there in drivability? Can the 4 speed non-turbos still do 70 on the highway? Handle/steer/brake the same or close enough? I’m assuming the shocks/ride quality is improved too?
how much more would you pay for a rev/ecv compared to an a2?
Coug
4,840
Olympia/WA
4 speed non-turbo can do 75 on the highway (as long as it's relatively level) no problems. The way the gearing is the non-turbo will cruise at a little lower RPMs than the turbo truck for the same speed.
A lot of the 1123 had an armor upgrade package, and the suspension is crap. As in, instead of 1200lb per inch compression in the front it's 3000lbs per inch compression. Ride quality is crap, but they corner like nobody's business (I have one of these)
Handling is relatively similar. The REV post 246890 serial number trucks do have some upgrades, but that also adds more things to fail and more expensive parts. Some parts were unavailable, and might still be difficult/expensive to source.
For the non-turbo trucks, serial numbers above 196900 have the remote power steering reservoir and a better brace for the rear of the alternator; it goes down to the block instead of the exhaust stud that can break off. Before that you can change the bracket style without much difficulty.
One nice thing about the ECV/REV trucks is the built in aircon. The non-turbo trucks you have to add it to, and while the red dot system does do cold air, it also takes up a lot of space in the cabin.
For comparable condition trucks, you're probably looking 8-10k more for the ECV/REV than an A2. If you're not going above 55mph, the A0/A1 M1097 with the 3 speed is even less complicated by having no transmission computer, but again no aircon and only a 3 speed. I'd expect about $5k for a 3 speed truck than a 4 speed.
A lot of the M1097 are R1 trucks, which have neem discussed on here a few times, but it's a truck that got upgraded to heavier suspension. They can be either 3 speed or 4 speed non-turbo. Just something to be aware of when looking at the M1097 series.
Coug
4,840
Olympia/WA
The ECV/REV will definitely seem like more power compared to the A2 trucks, due to a little lower gearing plus the extra power from the turbo.
190hp vs 160hp.
3.08 differential gearing vs 2.73
Personally I've had my M1123 cross the scale at 13,500 lbs between truck and trailer, with the BEOD on the truck making for additional wind resistance, and still was able to do over 65mph on level ground.
Going uphill was a different matter though. Going up a mountain pass I spent a lot of time at 30-35mph with just the truck weighing somewhere around 9k lbs. I haven't driven the ECV/REV under comparable conditions, but I imagine the extra power, gearing, and turbo would definitely help.
About the biggest argument I can make for and against buying a second REV truck is parts compatibility. You'll be able to keep one truck running while waiting for parts, and only have to keep one spare set of parts around, such as they use different brake pads between A2 and REV.
On the other had, the A2 parts are cheaper/easier to acquire for a lot of them, so if the parts like the steering box and geared fan drive have issues, you have a truck that uses the basic version that's easier to replace.
thoner7
238
NE TN
Thanks coug. I am aware of the differences on paper, but not in real world “feel” or how that would translate to daily driving.
I’d prefer another rev just for familiarity and parts but they are harder to find and more money.
M1165A1
921
The High Country, CO
My experience driving my own REV B truck (turbo) vs my buddy's NA 6.5 is that the turbo makes a lot of difference on mountain roads. 2 of the 3 principal exits from my town cross the 10,000 foot mark and the NA version struggles to climb up those passes without dropping to a speed that necessitates the 4 way flashers. But that's a pretty specific set of driving conditions.
mrfarb
204
Texas
I’ve had both - 1097A2 I drove a lot and currently a 1151a1 REV truck. The 1097A2 was much nicer to drive on the highway actually. The downside was no a/c, and the ultimate reason I went to the newer truck. But miss that truck sometimes. IMO the 1097A2 is a great choice.
My suggestion is if you get an A2 truck, spend the money and ditch the military hydraulic fan clutch and put a viscous fan clutch like normal vehicles have - makes a huge drivability difference you’ll appreciate if you currently have a REV geared fan.
thoner7
238
NE TN
How did the suspension and steering compare? Braking?
I had read that about the fan and it’s likely something I would do
mrfarb
204
Texas
My 1151 is heavier so it’s hard to compare brakes, but braking was fine on the A2 truck. Steering is comparable between the two.
Coug
4,840
Olympia/WA
The REV does have stronger brakes, but not by enough to worry about unless you're going to badly overload the A2. A2 maxes at 10,300 gross weight and REV can be max 15,500 gross. I know my M1123 will lock up the brakes at over 9k gross weight if I really stomp on them, so can't really ask for much more braking power.
GuntherRommel
533
Bend, Oregon
I feel like the 1097A2 and 1123 trucks are much faster top end speeds, going uphill or on flat ground . Also way less RPM at that speed. I Can maintain 60-65 uphill. 80 on flat, new injection pump
thoner7
238
NE TN
would the 1097a2 also have this armor upgrade? And therefore crap suspension?
Coug
4,840
Olympia/WA
Not that I know of.
The M1123 is the Marine Corps equivalent of the M1097A2, with the fording kit already installed and the rear bumper removed because the Marine Corps didn't want the bumper. Many M1123 got an armor package called the "Marine Armor Kit" (or MAK for short) while in service. The M1097A2 was primarily an Army truck, so would likely not have received it.
I believe that it is both the spring and the shock that get replaced, and some people have had decent improvements in ride quality (or so they report) by just changing out the shocks.
There are also plenty of M1123s that didn't get the MAK installed.
The springs aren't really that hard or expensive to replace. The only thing you need to pay attention to is the rear spring upper mount as there are 2 different mounts for 2 different lengths of springs. There's one of welded steel, and another that us cast as a single piece. One isn't better than the other for any particular reason.
Plus some people have had luck using springs from certain years of Nissan Armada cut down a little to fit that soften the ride.
thoner7
238
NE TN
Maybe I should start a new thread for this but - the 6.5 motors made by GM with a GM sticker, v the GEP6.5…. Would the GM 6.5 potentially have the #8 cylinder issues? I believe the GEP motor would be considered superior???
Coug
4,840
Olympia/WA
GEP is considered superior, but I have been told the last few years of the GM 6.5 that they did do improvements to the metallurgy.
It doesn't really matter what year the truck was originally manufactured, they all pretty much go through rebuild at about 10 years old, and they always throw in a rebuilt motor. Only way to know is to look at the date marks on the engine or find the casting marks on the block showing GEP. Plenty of engines got whatever set of valve covers were lying around at the time, so a GM sticker doesn't necessarily mean a GM block.
thoner7
238
NE TN
That’s good to know about the stickers.
I’m looking at ones that are out of some national guard bases, would they have been been rebuilt too? If it’s a 1999, would it be rebuilt in 2009 and 2019!?
Coug
4,840
Olympia/WA
Typically it will get a new data tag on it during rebuild that will show it's original serial number, the date of rebuild, and how many miles it had on it at time of rebuild (not that it really means anything with how easy it is to replace the speedometer)
They also only typically get one full reset/rebuild at around 10 years, then get disposed of around 20 years. Lots of other factors in their decision to dispose of, which is why we have a lot of REV trucks on the market. There are also still some 3 speed trucks, but most of those were the M1097R1 trucks that were regular variants that were rebuilt to the heavy version (M1097 is considered the heavy hauler compared to the M998) because the military wanted to have more trucks they could bolt armor to if necessary.
I don't know if the National Guard vehicles are on the same maintenance rotation as active duty trucks, but I would imagine so. The biggest enemy of almost any vehicle is sitting and not being operated, as opposed to being operated regularly.
I know that the Marine Corps had a lot of trucks that just sat out in the desert for decades just in case they were needed, then auctioned off at end of life. For example my M1123 had a rebuild date of 2009 with 26 miles on the tag. When I went and picked it up it had 32. Engine was a rebuilt 2004 GEP block.
