- 2,139
- 98
- 48
- Maine USA
In a previous thread I documented the install of a battery equalizer to replace the DUVAC system in my M1010. Well the equalizer lasted about 4 days and quit, of course it's a non repairable sealed unit. The equalizer was given to me so I was not too upset at it's failing, better home than on a road trip.
So plan "B" went into operation by replacing the top 24v alternator with a Leece Neville(110-555JHO) 12v 160A 1 wire self exciting alternator. I chose this one as it fits in the existing mounting bracket and eliminates the need for a ignition circuit to turn it on making the install much easier. I re used the original pulley and it also uses the stock length belt. Once installed simply re use the ground wire and run the hot wire over to the battery. I placed the lug of the cable under the head of the bolt on the battery terminal. To recap the DUVAC removal I just removed the wiring from the DUVAC, taped each connection and folded it back, taped and tie strapped it back to itself, same for the top alternator wiring. There is also a wire(mine was orange) going to the 12v buss that needs to be removed and taped. Now I have a reliable, servicable 12v supply to the 12v system. The alternator is a standard over the road heavy truck unit and according to Prestolite is "A" or high availability making service or parts easy. I still have the 24v alternator in the bottom location so the electrical system has not changed making all the original items still operable, AC, slave port, rear heater, etc.
