ridinshotgun
- 0
- 1
- Mineral, VA
So I have an 003A that is giving me issues while running where it seems to be losing engine power. I think it is a fuel issue, possibly pump related but wanted to see if anyone else might have some insight on diagnosing the issue. The issue is that the engine appears to be losing power and surging. It may run fine for a few minutes and then loses engine power that surges back.
I read through the troubling shooting section in the manual for an engine that lacks power and checked the air filter and fuel filters and strainer. They all appear good and oil pressure seems to be OK. When I shut it down and Try to restart it one of the fuel pumps does not sound like it did prior to this issue showing up. Instead of the hard tick like normal it sounds dull and very quick.
In the service manual it gives instructions on how to check the fuel pressure but other than a normal fuel pressure gauge is there any special adapters I need to hook it to the pump for a test. Want to make sure I have what I need prior to starting the work.
Am I missing anything or does anyone have more insight on my issue or think I am chasing the wrong problem?
Thanks!
Thanks!
