'03 M1045A2 idle surges
LoveThySpatula
Marysville, WA
So, long story short, my voltage regulator was shot (200 amp generator, dual voltage regulator) so I replaced it with a brand new N3135 regulator. Now my voltage output is correct, however, an issue I had prior that was not corrected was that the idle would surge temporarily for about 30-60 seconds after start. You can see the voltage gauge on the dash drop to yellow, then surge to green, rinse and repeat for a little bit, but definitely under a minute. After which, the gauge and idle return to normal and I get dead-nuts-on output at the regulator and batteries.
The operator's manual states to let the vehicle warm up for about a minute - are these symptoms considered "normal" or is there something abstract occurring here?
Thanks in advance - I am pretty new to Humvee ownership and did search for a similar topic but to no avai l
Action
1,553
East Tennessee
29 volts output at regulator and batteries at idle. Before I was getting what I discovered was just battery power (a sporadic 24-ish volts and no change in battery voltage from off to start).
PCB is the KDS CR-2695 it seems.
Yellow label box?
From memory, that one will pulse the glow plugs after startup. The volt meter will move from yellow to green as the plugs cycle on and off for a minute or so. The headlights will dim and brighten. 28.8 volts while running is normal..
LoveThySpatula
Marysville, WA
Yellow label box?
Yep, yellow label box.
That's what I was hoping to hear... Just couldn't find anything conclusive. My voltmeter reads 29 volts but it was also dirt cheap, so it may be off by a hair.
Appreciate the info and quick responses.
AAVP7
261
Dortmund, Germany
My M1045A2, which I have almost three years now, has the same symptoms after every startup, so seems to be normal afterglow.
However, watch this every time you start. The afterglow cycling needs to stop after one or two minutes.
I once (in deep winter) had the afterglow continue forever. Or at least the almost five minutes I waited until shutting off. At the next try, everything was back to normal. Some hiccup in the box I guess.
LoveThySpatula
Marysville, WA
Good advice, appreciate it. The cycling always ends within a minute so I think I'm doing well. I will definitely keep an eye on it though.
Thanks for weighing in - there's not a lot of info about this situation out there.
