1/2 ton bed crane mounted in my M1102
86m1028
17
Murphy TEXAS
Nice job !
Will if lift high enough to get bigger things in the bed
What brand & model is the hoist ?
FloridaAKM
392
Gainesville, Florida
Thanks for posting that neat mod. I may need to copy your idea for one of my trailers as I am getting too old to lift a 55 gallon drum; wait, I could never lift a 55 gallon drum that was full, so I can't blame it on age.
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
I guess better late than never, it'll lift a full 55 gallon drum no problem. I would like to mount a small which on it to help speed things up though.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
I put a Horrible Freight 2500lbs atv winch on the crane I made for my deuce bed, works GREAT! I'd have to make a spare mast for that so it could swing over the bed side if need be. Couldn't be too hard to fab up.
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
The crane comes with some angle iron pieces that I put under the bottom, then I whittled some aluminum pieces to fit the corrugations of the floor. I'll try to remember to take some pics.
Sent from my XT1080 using Tapatalk
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
IMG_20170125_134142820.jpgIMG_20170125_134153766.jpgIMG_20170125_134207881.jpg I located the crane to have the forward bolts come through the aft wheel well cross member, then cut the angle that was supplied with the crane to spread the load. The aluminum wedges I made so the crane would sit flat over the corrugations.
