Can anyone tell me if someone if reproducing 1/2 track fuel tanks in stainless?
also
![rear floor supports 2.jpg rear floor supports 2.jpg](https://www.steelsoldiers.com/data/attachments/396/396295-12906a9a3d6152f38ae3f7f839828a74.jpg)
I need some help and parts to correct the flooring supports and side supports in my halftrack.
I know some of it is wrong, but I don't know how much.
If you would be so kind as to take a look at the attached pictures and let me know what I need to make it correct. I would greatly appreciate it. I can take more if you need them.
Mostly I believe the angle iron does not look correct and the supports for the front of the rear seats, and anything else that hold up the floor.
I am also looking for pieces of skate rail, a trolley, a rebuilt hydrovac system, top bows, volt meter, rear bumperets for the rear mounted storage boxes, mounts for rear lights and trailer socket, stainless gas tank, cap and screen for gas tank, rear wiring harness, ammunition box for drivers side with shelves, and shelves for passenger side.
I believe I should also have a grenade box or two.
Also, is there a manual or book that shows what goes where and the size and lengths of the bolts used to put things together with?
Also, is there an easy way to tell original armor from repro? Can I use a center punch and see if it leaves a dimple?
Thank you in advance.
Dj
also
Dj
