Westex
- 6
- 18
- El Paso, TX
Is it REALLY necessary to filter used engine oil down to one micron to burn in our multifuel engines? Will 3 micron do?
Not to be nitpicking, but the original Purolator/Facet filter elements are 4 micron nominal, 15 absolute (P/N 053161-04). The primary water separator/filter is 40 microns...I have been going down to 5 micron, the trucks filters are 10. I would say the cleaner the better but with diesel at $2.50 a gallon you will reach the point of diminishing returns pretty quick.
Yes Diesel probably does have some carbon in it. But in WMO you can see it....and a lot of it.
GKW=God Knows' What
Waste Veg Oil
Waste Moter Oil
Trans Fluid
Old Gas
Old mixed Gas
ect,ect,ect.........
cranetruck said:Not to be nitpicking, but the original Purolator/Facet filter elements are 4 micron nominal, 15 absolute (P/N 053161-04). The primary water separator/filter is 40 microns..
gimpyrobb said:I would say yes, others say no. I pump my wmo through a deuce secondary/final filter from the side of a motor and then to a 5micron absolute filter spin on. Been doing it for a long time
Black Chalk, that may be a precurser to a coolant leak, with the loss of a shiny look to the oil. Typically contaminated oil looks like foamy chockolate to foamy licorice looking. Could be insuficient warm-up time causing condensation, but if it starts changing color to the browns, thats a red flag, so keep an eye on it. One tale-tale thing to look for such as a bad head-gasket are slight bubbling in the radiator with the cap off. You should be able to see it clearly as pressure is forced from the cylinder through the leaking gasket into the waterjacket and out to the filler snout.The oil from my Deuce looks chalky (black chalk)
