10 bolt wheels
redneckracerx
Voorhees, NJ
I'm in the market for5-ton super single wheels to run 16.00-20 michelins. I came across a set of 7. They are the 2 piece 10 bolt style. My first question is will they work with this size tire? Second, is the price good?
jwaller
19
Columbia, SC
yes they will work just fine. thats the combo I have. you didnt mention what the price is but anything around 200/wheel is normal. if you need tires I have many 1600's I need to sell.
M1075
Oklahoma City
Ideally, you want 2 piece rims from the M939 series 5 tons (A1 or A2 models). FMTV and HEMTT rims can work, but are not the best choice. For the ones you are looking at, how many bolts hold the rim together, 10, 12, 16 or 20?
guner51
Metamora, Illinois
RE: Re: 10 bolt wheels
you guys are talking about two piece rims, so does anybody got the nuts for these that hold them together?
I got 10 rims but don't have any nuts.
jwaller
19
Columbia, SC
seco in augusta, ga has the nuts. I just had to buy some. they are the real deal part but they are about $10/nut. you could use grade 8 from the hardware store for about $1 each.
dma251
15
Arlington, Washington
all they are is a 3/4" flanged frame nut with a black oxide coating on it. They really are nothing special.
What's special is the darn valve stems - they are tricky to find and rediculously expensive if you do.
Cdub
New Milford, NJ
I had to replace the valve stem on my spare and Yes, it cost me big $$$......
Each of the four combat wheels I dismounted the tire from did have the bead lockers inside them.
seya,
C'dub
steelsoldiers
3,967
Charleston, WV
Yep, I broke a valve stem on one of mine when I was installing the CTIS valve! Argh. I got one from Winslow. There is a company that sells the OE ones. I found it by Google'ing the P/N. I think 1075 found a supplier too. They aren't cheap anywhere though.
