1008 driving through a ditch
rizzo
Port Huron, MI
DavidWymore said:
Try it with a locker in the front and some 395/85/16 XMLs
haha just bought a locker. I havnt picked it up yet. the seller bought it for some rockcrushers with 4:10 gearset. he says it will work with the 4.56's in the 1008.
he has two rockcrusher housings for sale if anyone is interested
Davidwyby
244
CA
I had a 4.10 locker I was gonna use. Didn't fit. The carrier split is between 4.10 and 4.56. Can be done with a ring gear spacer, but it's not recommended.
Pirate4x4.com and ck5.com have good info on building these trucks. They can be pretty unstoppable.
I have an 88 K5 blazer and my brother has an '81 K10 stepside, both with locked one tons and 38" XMLs, crossover steering w/ hyd assist. They work pretty good.
rizzo
Port Huron, MI
???? DTS says the only thick gears they have are reverse cut. I told them the story. they said make sure it is the right spline also they come in 3 sizes. any idea on what spline the 08 is?
Davidwyby
244
CA
Yah, maybe. I know the front 60 is 35. I can't say for sure that I've had a 14 apart. My 70 rear was 35.
1,824
Just checked, they are 1 1 /2" but an odd pitch 30 spline. Still strong as can be for a pickup.
CCATLETT1984
Saint Clair Shores, MI
dissregard my post, i had a brain fart, he's adding a locker to the front. I was thinking of the other thread mentioning 14bolts. Turns out that NO ONE makes std. cut thick gears for the dana 60. so that locker is useless to you. you could weld up the carrier for now.
