1008 questions
From the CUCV Wiki:
Brake Fluid
  • Fluid is DOT5 silicone only. CAUTION: Some of these vehicles may have been filled with DOT3. There are numerous arguments for using either kind. However, do NOT mix them.
  • Level should be ¼” below lowest edge of each filler opening in master cylinder
1,192
If you read the info on the top of your master cylinder cover, it clearly states, use dot5 only.
Also, please take note of the forum you are posting in, and try to post in the correct forum.
