100A -> 200A/400A alternator replacements
Awesomeness
1,518
Orlando, FL
I have a '97 1078 with the 3116 engine. One of the mounting ears for my alternator is broken, and I'm wondering if it is worth upgrading to one of the 200/400A models? Are they direct swaps (my TMs only list the 100A, with no mention of the 200A and 400A).
Thanks!
DiverDarrell
24
Port orchard, WA
200 amp comes as a kit. Suprman has them. Replaces a lot of parts. Instructions are limited. Since I hope to some day convert mine to a camper I opted for the upgrade when my alt crapped out. In reality the amps are split between the 24 and 12 volt side. So I'm not sure if you get the full amps per voltage. If you bump up to the 400 amp you would have to replace a lot of wiring to handle the quadrupled amps
scottmandu
36
Texas
Still have the broken alternator? I just need to get a good rear casting plate off it.
I have an old style alternator that has good castings. The depot monkeyed with it and I could never get it to work.
I've been unable to find an alternator larger then 200 amps that will fit on the truck. The 400 amp alts are huge and won't clear the turbo intake, and if they are moved outward will hit the shock tower and body.
I've also considered mounting a 185 amp 3KW 28VDC diesel gen set side saddle which would be a better choice if one want to charge batteries without running the main engine.
sarge351
Allen, Texas
I am interested in doing the same upgrade: 100 amp to 200 amp, Kit # 57K1912. Can you give me any more information? I have the Cat 3116.
The main component of the Kit is the Alternator N1216 200 amp Alternator. The street value of this is $500-$600 on fleabay. The street cost of the Kit is $1600. So I am paying $1,000 for mounting parts I may or may not need. I am paying 2-3X the cost of the main component just for the correct pulley and/or bolts?
Am I wrong in feeling jacked in paying $1600 for the complete kit? Is it worth the upgrade?
Sent from my iPad using Tapatalk
Suprman
696
Stratford/Connecticut
Have to check. I dont think I have any kits left. Its more than just alt and mounting. Has some new wiring and 200a power protection block. Which can really be eliminated as long as you never hook up the batts backwards. I have the armored apu 28v gens. They are rated at 5kw. You could find a 24 volt only alternator and use a 100a equalizer to maintain the 12v. May have to use some contactor relays to switch the equalizer you dont really want it powered idle for long periods it would drain the batts over time. Any way you go its still not cheap.
ZiggyO
444
Nebraska
Why buy on ebay when you can get the whole kit from me on here for far cheaper...... pm me for details......
Z
thetruckguy
silver creek ,NY
I did the 200 amp upgrade when I bought my m1088 because the original was missing. I managed to find a reasonably priced alternator, but it was **** finding the correct pulley. I ended up fabricating a bracket. It was hard to figure out the wiring without instructions too. I am now finding out I may have hooked it up wrong. I would say doing it as a kit would be better, and less stressful if you can find someone selling one that actually has a conscience. Some of these surplus resellers really inflate the prices when things are hard to find.
scottmandu
36
Texas
Welcome to capitalism and supply and demand.
Suprman
696
The last time I saw the complete kits at auction they went for over 650 each plus tax fees and shipping. Military trucks is not a cheap hobby.
sarge351
Allen, Texas
Thank you for the input! It is helpful to get the feedback.
I would agree with Suprman. This is not a cheap easy hobby. It is more like an expensive quest.
FarmingSmallKubota
1,109
Wapakoneta, Ohio
I know this is an old thread but i have a nos 200 amp alternator coming from the Gov auction site. with out the complete kit does that mean this is worthless?
Awesomeness
1,518
Orlando, FL
I believe the complete kit included replacement wiring that is heavier duty, to handle the increased amperage, as well as possibly other higher-rated components (e.g. polarity box?).
GeneralDisorder
5,196
Portland, OR
The 260a alternator from Niehoff is about $3400 retail with regulator.
You do need a different shock tower and different mounts and of course larger wiring, but I don't think that would amount to $12.5k
Awesomeness
1,518
Orlando, FL
Military spec stuff is really expensive (several times the cost of similar consumer products). That kind of pricing sounds pretty appropriate.
coachgeo
3,461
North of Cincy OH
I have the 200amp alternator just not all install kit is the only reason i checked
My 200amp from a hummer installed with a hacked spacer to make it work with the different ear spacing from OEM 1001mp dual volt alt on FMTV A0. Also had to drill out the ears little wider to fit the bolt if I recall right. Had to move the regulator. Presently just zip tied to a spot. Ideas came from Fastidious Restomods youtube install of his.
