1028A3 motor change
FMJ
37
Las Cruces, NM
Finally got around to changing out the motor (blown head gasket when I got it) with a HMMWV 6.2 take out motor. The oil pan does fit the CUCV, thanks Kenny!, Swapped out all the quick disconnect sensors with the CUCV stuff, hope to fire her up tomorrow.
Ed
FMJ
37
Las Cruces, NM
The rest of the bottles are in the trash can!
Anyone know if the HMMWV oil pan holds the same amount of oil as a stock 6.2 pan?
FMJ
37
Las Cruces, NM
Well, the HMMWV motor is officially a DUD!, I need a good 6.2 now. . .
I got laid off from my job at White Sands Missile Range, and need to find a good motor for this truck before I put her up for sale. I'm starting a job at Nellis AFB later this month, but would like to offload this A3 in a running condition before I head north. I may be heading out to Charleston SC, via Columbus Ga. next week, if anyone has a GOOD, low mileage 6.2, I'd be interested!
Ed
FMJ
37
Las Cruces, NM
bad miss, loud metallic banging sound. . .:p
Motor turned over by hand fine, but when I put a starter on it, it spun over WAY to easy. . .
ralbelt
9
West Warwick, R.I.
I don't understand why you don't fix the original. My 6.2 had a blown head gasket and a cracked head on the same side, replaced that and had the other side checked and machined, replaced a few bad valves on that side all new gaskets a hmmv intake from Gimpyrob and runs great.
Seems like you will be gambling on another engine if you can't hear it run.
FMJ
37
Las Cruces, NM
Does anyone know where you can get a running low mile 6.2 for a 85 m1028A3 in the Las Cruces NM, Las Vegas NV area?:jumpin:
tvguy
Duluth, GA
Ed
Are you still heading to Columbus, GA? I've got one I might be willing to let go and I know of another one locally (Atlanta) as well.
