1078 driver door window install.
Blairg
105
California
Anybody have experience doing it? Went through the Tm/s to see if it was covered but couldn't find it. Window was very easy to get out after I broke it accidentally. I was a moron.
Blair
TomTime
1,672
MD.
I know you have the LMTV 4x4, but I can only tell you for the MTV is,
TECHNICAL MANUAL
MAINTENANCE INSTRUCTIONS
UNIT MAINTENANCE
M1083 SERIES, 5-TON, 6 X 6,
MEDIUM TACTICAL VEHICLES (MTV)
VOLUME NO. 4 OF 5
9-2320-366-20-4
Chapter 16 Body and Cab Maintenance
Section 16-5
EDIT: I found this. Maybe this will help.
Got to post, #28
Good luck,
Tom.
TomTime
1,672
MD.
Blairg
105
California
Should be: 9-2320-365-20-4
I looked in there. Beginning to think my PDF's that i down loaded didn't download completely. Going to go through and re-download to be sure.
Thanks again!
Blair
Blairg
105
California
It's easy. You just remove the inner window sweep and the weatherstripping in the glass channel and along the top edge and the window slides out to the inside edge of the channel.
Interesting. Deed is done now. I ended up removing the aluminum channel by drilling out the rivets. TM states that some had screws while other had rivets. I will replace them with screws in the event my dumb areaks another window.
Overall pretty easy.
Blair
