10k half shaft disassembly
rcamacho
827
Bainbridge Island Wa
Getting stuck on how to disassemble the shaft joints for inspection and boot repair. I would prefer to disassemble from the hub side as the rotor side outer snap ring looks like a destructive process (its not moving)
Rotor side with external ring
Hub side. Inner snap ring moved however it will not tap off shaft.
rcamacho
827
Looks like the rotor side CV is specified for disassembly in the TM. Suggestions how to get the retaining ring off in one piece or replacement part #?
DatGuyC
22
Essex, Maryland
When I took mine apart the rotor side was super easy. The retaining ring was just a split ring that popped out with a flat head screw driver and the CV balls just slid out of the housing. Are you sure those are 10k and not 7.5k half shafts? I think the rotor side of mine looked a little different than the picture you posted.
ken
25
Houston Texas
I think this has been answered before but I didn't find it. Can 10K shafts be swapped directly for 7.5K's?
rcamacho
827
Stilltring to figure out 7k disassembly if the rotor side ring is a destructive removal. Thinking I’ll go to 12k shafts next time
rcamacho
827
Used “pipe trick” method to separate hub side CV joint. Used (2) 1x4 pieces of lumber under the CV from either side and some gravity assisted hits. It only took 3 hits.
Now re-greasing and booting the shaft.
