11.00-20's on a Deuce....
dm22630
42
Front Royal, VA 22630
After my current learning experience with the rear wheels/tires on my deuce, I have decided that on that particular one I want to go to "super singles".
I know that 11.00-20 tires fit on the deuce rims, but do ALL 11.00-20 tires fit, or just the standard non-directional ones?
I would like to go with some that are meaner looking....but will they work with that rim? What tube/flange would they use?
Thanks!
Westech
CPL
6,104
207
cow farts, Wisconsin
RE: 11.00-20
yes A 11:00 x 20 will fit a deuce rim. all 11:00 x 20's will fit. thats the size, just because the tread is different style don't mean its a different size
Capt.Marion
15
Atlanta, GA
RE: 11.00-20
I am a newbie to tires, and this seems the opportune moment: Is the "11.00x20" rating in reference to the inside diameter of the tire (the outside of the wheel), then?
dm22630
42
Re: RE: 11.00-20
As far as I can tell.....
It means 11 inches of rubber then 20 inches of rim then 11 inches of rubber = 42 inch tire (height)
A 9.00-20 is 9 inches/20 inches/9 inches = 38 inch tire (height)
rhinomike
york,pa
RE: Re: RE: 11.00-20
I want to do the same tire choice too! someone posted a truck with that set up on some deuce thread in the past six months. with pics. please post what you find and your pics. when done.
M813rc
3,035
Near Austin, Texas
11.00, 9.00, 14.00 etc is the width across the tread, not the height. xx.5 (or .50) tires are usually shorter heightwise compared to xx.00 tire. Example- a 12.5-20 is roughly the same height as a 9.00-20, but has a wider tread.
Cheers
m16ty
211
Dickson,TN
Cheers
11.00 is the width but on most tube type tires the sidewall height will be the same. A 11.00-20 is quite a bit taller than a 9.00-20.
