that should work- I can't find the page now, but I saw one where a guy had 11x20 duals with no clearance problems. It all comes down to brand, apparently they can vary widely. Just make sure there is at least one inch clearance between the tiresOriginally posted by big mike
i do occasionally haul some heavy stuff like firewood or a truck. if i have rubbing issues, i might torch up some old rims i got outback and make a spacer for each corner in the back if i got enough wheel stud to do it safely. it would gimme atleast 1/4" more room, if not more. what do you guys think about this idea?
That's my setup and now a couple years later no problems and thousands of miles. I run 60MPH and have 6500LBS in the bed and I go offroad. Pressure is kept to at least 40 at all times, and generally 60 for on-road use. 11.00x20 have higher pressure ratings and much higher load ratings.
