1100rX20 XL Michelin
2deuce
154
portland, oregon
I'm selling some of these (new ones)and the buyer wants to know the width of the tire after its mounted on 9.00x20 deuce rims. I think the height is 43.1". I need the width.
hornetfan
Lamar county, TX
I happen to have the Michelin data sheet for the XL series open when I ran across your post.
11.00R20 XL Load Range-H Load Range-35071 Loaded Radius-20.1 O.D.-43.1 Overall Width-11.1 recommended rims-8.00, 7.50
I am new to the M35 and I am not sure what the stock 9.00R20 rim width is. You can run perhaps 1/2" narrower than recommended but more narrow than that will cause problems at low air pressures. Wider rims will result in approximately 1/4" additional overall width per 1" or additional rim width with Michelin XL or XZL tires. The sidewalls are very stiff and overall aspect ratio is very high so the width doesn't grow as much as lighter duty tires.
I hope that helps.
11Echo
92
CT W. R.
Somewhat useful Michelin guide.
Army Military Tires
There is no problem mounting them as dualls. I run XZL's and they are wider.
hdmax
new Lexington, Ohio
I measured mine the other day only to find out that they were just about 1/2" wider than the 9.00's both mounted, aired up on stock rims, but off the truck. (So no weight on them!) 9.00's are 10 1/4" wide, tread is 8" wide, height is 40.4" the 11.00's are 10 3/4" wide with a tread width of 8 3/4" overall height is 42.8"
Both have about 90-95% tread.
Hope this helps.
jcappeljr
27
Delta, PA.
I have 2 of them mounted on wheels for sale if anyone is looking,I can take some measurements if somebody need me too.
