1123 suspension
$lim Tony
Chelsea, AL
I have a 1123 A2 MAK. It still has the stiff up armored suspension. I am looking to soften that. Can anyone direct me to which springs I need to order, and where can I order them from? Thanks,
Coug
4,673
Olympia/WA
There are several different spring options for the HMMWV depending on how you plan to have your truck set up.
There are also several aftermarket spring sets available. The aftermarket springs will be the ones to soften the ride more than the military ones, as a soft ride wasn't on the consideration list when designing the truck.
You'll also want to check and see whether you have the welded or cast rear spring perches, as it affects which springs you can run in the rear of the truck. Some of the MAK armored trucks got the cast perches, some still have the welded.
(I have a buddy that just received 2 M1123s that are close in serial number, but have different springs under them and different serpentine belt setups, so you don't always know what someone has just from the model)
$lim Tony
Chelsea, AL
I
