118712 24 volt military coil from Boyce
firefox
General
1,844
51
Berkeley CA
Hi All,
I just bought a 24 volt military coil from Boyce, but the connection at the top is new to me.
Physically it is the same sort of format, but instead of having a metal lining to the inside of the
hole, it is just the plastic side of the hole. There is a metal bottom to the hole as though you were looking at the end of a sawed off brass rod.
Is anyone familiar with these coils? I need to make up a wire that goes from there to the distributor which is just your standard civilian type 12 volt distributor that was put into
this old XM211 along with a manual transmission.
JasonS
195
Eastern SD
Normally, the high voltage receptacle shell is held in with a screw; maybe this was forgotten when manufactured? You know, you don't need a special coil for 24V. The M35/ M135/ M211 military distributors used a standard 1.5ohm AC delco coil. You just have to limit the current through the points. I use a 3ohm pertronix coil and two 1.5ohm ballast resistors.
firefox
General
1,844
51
Berkeley CA
Thanks Jason,
I realize you don't need a 24 volt coil, but I was trying to keep things simple and avoid mounting resistors, etc.
The strange thin g about this coil is that it not only has that flat contact area in the bottom of the hole, but it
has two tabs that stick out with holes in them at the top of the can which appoear to be
for securing some kind of cap or some such. The other thing that is strange is that the can is
chrome plated. I figure it was intende3d to be inserted into some holder of some kind.
