I've been somewhat curious what sort of fuel mileage I'm getting with my Deuce, so I ran a little test. My fuel gauge doesn't work (although I did fix that yesterday with a new fuel gauge), so I had made up a dip stick calibrated in gallons in order to keep track of how much fuel I had in the tank.
I started my test on June 27, according to my dip stick I has 20.6 gallons in my tank and my odometer reading was 16894.5 miles. I ended on August 10, my dip stick read 20.4 gallons in the tank, my odometer reading was 17194.3 miles, and I had purchased 24.99 gallons of fuel in that period.
With a little simple math, that comes up with 25.2 gallons used to drive 299.8 miles, or 11.89 mpg. However, my odometer reads 5% low, as verified by both my GPS and comparison readings for point to point trips with my '05 Chevy Venture. Figuring in the 5% correction, my actual mileage for the Deuce is 12.51 mpg!
I was impressed, to say the least! I was expecting 8-10 mpg at best. But I am running singles on the rear, and most of my driving is on rural roads at 40-50 mph. Only about 100 miles was at highway speeds in the 55-60 mph range (actual speed per my GPS, the speedometer reads about 10% low).
All in all, not too bad. I've owned several 1/2 and 3/4 ton pickup trucks that only averaged 12-15 mpg, so I guess I'm doing OK with my Deuce!
