12 Volt power source for 939 Trucks
bchauvette
12
Easley SC USA, 29640
I figure that if the design engineers figure it is ok to feed a blower motor at half voltage it shouldn't hurt to power a GPS and/or charge your cell phone. There are several threads on running your own tap directly off the battery touting the liability . Another benifit of tapping off the switch is that it has its own protection. Not to say you shouldn't put lower rated fuses for your low amp aux circuit. Keep in mind if you use a cigarette lighter outlet configuration a lot of plugs, not all, have built in fuses.
1,177
It was a compromise by the engineers and they certainly did not provide it for additional accessories.
Bad idea.
bchauvette
12
Don't agree!!! what do you suppose the current draw for a 24v blower motor running at 12 volts? as the motor ages? Current draw for a GPS or Phone charger?, micro amps. insignificant additional load. Maybe a microscopic additional miss balance. Maybe you have to add water to the front batteries a very little bit more often or change the tap to the two back batteries once in a great while. If I had more load than a GPS and/or cell phone I would install a 12 volt alternator with its expense and work to install.
swbradley1
Modertator
1,701
Dayton, OH
Butch, I would do either, I'd just use the 24v-12v converter from Pyle. $30 plus some wire.
