Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Bjorn is right: You can't rely on a 24V alternator to fully re-charge the battery that is being "tapped", since the current is split between the batteries. The one being tapped needs more than the other, so it will be undercharged, while the other will be overcharged. This is why the CUCV's have two 12V alternators (one for each battery - except the M1010 system, which is an entirely different story).
Patrick, let's say that you are using the lower battery extensively, (current exceeding the equalizer capacity) and then shut down the engine/charging system, do you not risk ending up with two poorly charged batteries for the next time the engine is started, or am I missing something?
I like POL (point of load) type regulators to keep from adding a 12-volt circuit to the already existing wiring. For example, the CB in my deuce has its own little 24 to 12 volt regulator in a box, tapping the nearest available 24 vdc circuit.
