corelokt
- 2
- 16
- Duffield, VA. (East of nowhere).
How much of an amp draw does the 12v feed draw at max? IE. How much is the most current going through the wire from the front battery to the 12v connector with the glow plugs running on the same circuit?
Also, if a component has a separate ground, ie. a ground wire and no ground through its' case, can it be run off the back battery bu connecting to the bus bars?
