hobie237
- 5
- 0
- Newark, DE
Been reading up on doing a 12v conversion. Found this article: http://www.roscommonequipmentcenter.com/news_notes/nn10.pdf
I have a few questions:
First, I'm having trouble understanding why I can't simply run the batteries and alternators in parallel rather than in series, thus retaining the same wattage available. Retaining high wattage is important for me since I want to have a big inverter on the truck for camping and working, it'll save me having to haul a generator.
I know the article says that "unless the voltage regulators' turn on points are identical, only one will be used" but I figure this is only really true in regular driving, as whichever voltage regulator has the lower turn on point will end up doing all the work in normal usage. However, when I end up hooking up a thousand or more watts worth of equipment, I like the idea of having an auxiliary alternator to avoid drawing down the batteries. It's fine with me if only one alternator is doing anything in normal usage, as long as I have the secondary one for when I need the power.
Second, I suppose a "worst case" scenario would be that I'd run two systems, separate from one another. The article talks about using a third battery for this, it seems pointless to me to do so. Why not just run two systems, each with one alternator and one battery?
Finally, can somebody tell me what the triggers are for the "GEN 1" and "GEN 2" lights? I assume they're just some manner of voltmeter that gives an off/on signal when the voltage is above/below some preset trigger?
Thanks for any and all input.
