12Volt Starter on Onan/Fremont Engines??
CapePrep
195
MA
Hello All, Sitting here in the northeast awaiting the impending ice storm and my mind wanders to potential projects. I am considering adapting a 4 cylinder Fermont motor to an old farm tractor. Does anyone know if there is a 12volt starter available for the motors or a way to convert a 24 volt one? Lets' put those thinking caps on....
robertsears1
119
Near Apex/NC
Why not go 24 volts on the tractor? We used to run two batteries in one of our tractors ( parallel not series) to aid in starting. You would need to change the lights to 24 volts but let’s be realistic, how many old tractors actually have the lights working?
Robert
Farmitall
276
Eubank, KY
You'll need a 12v starter, 12v alternator, 12v gauges and sending units for temp, oil pressure, 12v fuel pump.
No reason the engine won't work, but you might have to mess with the governor. I've not had one of these engines down at a low rpm idle as the governor wants to bring it back up to speed when moving the throttle lever.
jamawieb
522
Ripley/TN
Look on ebay for lpw4 starter and you'll find a lot of 12v starters for them. LPW4 is lister petter's manufacture code for the motor.
