13G vs 60G glow plugs
Herls
13
Massachusetts
Hello all.
Need to change the glow plugs on my M1009. I saw a post from 2019 where someone mentioned AC delco 13G and 60G plugs. I don't know anything about them, what is the difference between 13G and 60G plugs, which should I use?
Can you attach a link to the glow plugs you recommend so I can make sure I'm buying the right ones? (Advanced auto says they have a bunch close by but im second guessing myself as if they're correct or not.)
jcollings
391
Jupiter/FL
This is quoted from a very experienced member,
FYI
If it were my truck and I wanted to diagnose the glow plug system. I would pull all 8 glow plugs and bench test them. You could have 1 or more that are not glowing and they can return a false signal to the glow plug controller to protect the system. I may not have my terminology correct but that is where I always start. Get an eye ball look at them and make sure they are glowing at the tip. CUCVRUS Repair Projects | Page 6 | SteelSoldiers I have had a few that heated up against the threads and that caused an adverse no start condition. Good Luck. Report back. I will do my best to help from afar. And I always retain the stock system no ballast resistor bypass and use AC Delco 13G glow plugs. It has worked for me for 25 years and all my customer vehicles have the same stock unmolested system in them. General Motors spent millions designing it and it lasted a long time. No use hacking it up now. Have a Great Day and Be Safe.
Sent from my SM-G975U using Tapatalk
Barrman
1,771
Giddings, Texas
13G is what the system is designed for and work very, very well. They also can be swapped in with zero modifications.
60G plugs are self regulating. That means they heat up a little slower, but in theory will never, ever glow so long and hot that they swell or explode. If you have an override button or have a non working stock system that has any kind of button you push. 60G’s might be a better option for you. However, the electrical connector spade on the 60G’s is wider than the 13G. They either have to be cut down or the wire ends need to be changed on the glow plug wires.
Herls
13
Massachusetts
So the M1009 I bought was converted from a 24v system to a 12v system. It has a yellow push button for the glow plugs and 4 metal switches next to it for lights. So does that mean I should opt for the 60s?
cucvrus
10,431
Jonestown Pennsylvania
This news makes me very sad. And very sad for you as well. Good Luck. Who knows what and where they hacked the system. Poor CUCV.
nyoffroad
688
Rochester NY
Ouch! If it were mine and I wasn't going to convert it back to stock, then yes I'd opt for the 60s. I believe you will need to change the wire ends that clip to the GP's themselves, wait and check as it may already have been done.
What lights are the 4 switches for? I hope not headlights!
Herls
13
Massachusetts
Ahahahaha yea.....one of them is for the headlights, two of them are for led lights on the grille and one is just to cut power on and off to those led lights. Yellow button is the glow plug heater
19,750
Worthy of Consideration...
Those four switches.
Your left knee if you are in a head-on collision.
Bad MoJo! In a big way...
Think about what would happen if your truck "became much shorter" front to back. If the space that the human occupies gets crushed those switches will chew up your knee.
87cr250r
1,988
Rodeo, Ca
Look at the terminals on your current glow plugs. If they are 1/8 inch wide, you will want to run the 13g plugs. If they are quarter inch wide, you will want to run the 60g plugs. If you want to run 60g plugs for the self-regulating, you can cut the connectors off your existing wiring and install quarter inch terminals. I suggest getting the Packard 56 series terminals as they tolerate more plugging and unplugging cycles without loosening then a hardware store spade terminal.
nyoffroad
688
Rochester NY
Do you have AC in there? Or did the PO change out the bezel and do away with the black out light switches.
Herls
13
Massachusetts
Yup! It has a fully functioning heat and AC system installed by the previous owner. Also has all working dashboard speakers and two 6 1/2s in the walls infront of the rear seats
