ncduece
- 1
- 18
- wilmington nc
i put 14.5 xls on my truck single on the rear with the outer dual mount. at certain speeds i get a bad harmonic shake. at 55mph about ever 30 secs. i have removed the inter axle shaft to try find the problem. do i need to flip the hubs so the tire mass will be in closer to the axle? could the weight of the tire being mount ed a single outer dual configuration be the problem? at first i thought tire out of balance/round. i have a spare tire and have done some swapping and still have the problem. i have the xls on stock rims with tubes so getting them balanced seem to be a issue at the tires shops. has anyone done the hub flip and solved this problem? thanks
