15-20kw generator
Broke Down
Pineville,LA
alright guys i have a genrator that has a Hercules 4cyl engine (diesel). it has 3 facet pumps inline for the fuel system. two of the pumps won't run and i can't get it to crank. i don't know the model of the generator but i can look or what should i be looking for....lol. i just need some guidance on what to look for and where i can get the parts. or even better is there anyone here that has modified the fuel system to make it better? thanks guys
goldneagle
896
Slidell, LA
Is there a small stainless steel fuel tank near those pumps? If there is it is called a day tank. the pumps keep filling that tank and then turn off when pressure is reached. We could use some pictures with details of the generator and engine.
nopics
Broke Down
Pineville,LA
You will need to check the data plate on the generator, there should be a NSN or a Model number. Wayne
will do. i think i seen it last night. robbed some pumps of an old one a got it going
nopics
you are correct. i will see if i can get some pics up tomorrow. thanks guys!
Broke Down
Pineville,LA
alright i have been limping around the past few weeks and i got around to getting some pics. i hope this is what i need.
Broke Down
Pineville,LA
another thing is that it smokes when running. it seems to be out of time and dumping fuel my fathers generator has the same engine and uses way less fuel. it has a Hercules 4cyl engine in it. any ideas?
SCSG-G4
PSVB 3003
3,272
Lexington, South Carolina
MEP-004 with the acoustic suppression kit. Relatively standard 15KW generator, just from the first picture. I don't have one, but I've seen them before.
Broke Down
Pineville,LA
i was messing around the other day with these and my dad told me a trick to keeping the batteries up. we have a family friend that works on base and he told us that if we pull the e-stop it will keep the batteries from draining. tried it and it works! so if any of you have an issue with keeping batteries up you may want to try this. :beer:
