- 299
- 384
- 63
- Geographical Center of Virginia
Get ready for hurricane season with a quality generator! As close to "New" condition you'll find for an MEP-004.
Excellent condition super clean MEP-004 15 KW Diesel Generator 60hz. This unit was rebuilt and has a 2007 rebuilt Melton motor installed and is 17 original hours. Load tested and needs nothing. Can easily be installed for use in a home, shop, or other uses. This unit has been converted to 120/240 single phase and is rated for the same rated output as original 3 phase configuration. Mounted on HMMWV Generator Trailer. Fresh fluids, filters, misc new parts, and batteries. It was surplused to a county and they rarely used it. EMP proof, extremely heavy duty, much more reliable than the newer series (MEP-804) and easier to work on . These are rated at 15kw 24/7 use, only needing to stop every 250 hours for an oil change. You can easily get well over 10,000 hours of use before needing to rebuild. This is the most recently rebuilt Generator I've had. I have other MEP-005 30KW Generators available for sale. I've serviced and sold military generators for years.
Price is $5,000 OBO/TRADE. I'd prefer to sell this unit as the trailer/Generator combination.
I have other similar generator trailers for sale.
Located in Cumberland VA 23040. Yes I can load it on your trailer or in the back of your truck.
May consider trades for skid steer attachments, other military equipment/vehicles, and HMMWV 6.5T motor.
Yes, this item is relisted. The other buyer backed out of sale because they wanted something smaller.
15 kW, 50-60 Hz, Diesel Engine-Driven Generator. Characteristics: Description: 15 kW @ 0.8 power factor, 50/60 Hz, 120/208 V, 240/416 V Physical characteristics: Dimensions: 70″L X 36″ W X 55″ H Weight: 2450 lbs (1293 kg) Mobility: Fully housed. Mounted on skid base. Lifting and tie-down attachments provided. Fork lift provision. Engine: Diesel Horsepower: 45 @ 1800 RPM. Cylinders: 4 Cycle: 4 Operating speed: 50 Hz: 1500 RPM, 60 Hz: 1800 RPM. Fuel: Diesel Fuel Oil Electrical: Drip proof generator enclosure. Capable of parallel operation. Voltage Connection: 60 Hz: 120/208 V, 1 & 3 phase, 4 wire. 240/416 V, 3 phase, 4 Wire. 50/60 Hz: 120/208 V, 3 phase, 4 wire. 240/416 V, 3 phase, 4 wire Notes: Liquid cooled.
![152.jpg 152.jpg](https://www.steelsoldiers.com/data/attachments/682/682055-c24afb6fd2e823196be2ab124fbb724f.jpg)
