Rocco
Lynchburg VA
Ok I found a M52A2 That has a blown multi fuel engine in it.
I need to know has anyone /or is it possible to put a civilian NHC 250 Cummings in it ??
Where can I get the bell housing for it if it is possible???
Thanks.
1,158
I believe the M39 series of 5 tons does not have a long enough engine compartment for the Cummins.
I may be wrong..........
Rocco
Lynchburg VA
You looking for a decent LDS that the seller would take a blown engine in the deal?
What are you asking?
I don't know if I'm going to get the truck till tomorrow.
I would like to fix it up.
jatonka
90
Ephratah, New York
Rocco, you can put an International DT-466 in there and have great power(up to 245 in the older ones) and a bunch more useable RPMs. Up to 2850 with out over redlining. There is also a DT-540 with real big power but it is Electronic. JT out
m16ty
226
Dickson,TN
I don't think a NH250 Cummins will fit without some body modification. I think that's the main reason they went to a different front end on the M809 5-tons with the Cummins.
