cucvrus
- 10,455
- 113
- Jonestown Pennsylvania
I have a question about the VCV on the injection pump of my M1009. Last week I had short shifts in drive by 20 MPH. I went to the parts store and replaced all of the vacuum hoses top and bottom. Still the same. I purchased a new modulator at Auto zone and now it shifts late. And it hangs in 2nd till 50. And I mean hangs in 2nd. I disconnected the pass switch on the fuel pedal inside. No fix. I then adjusted the VCV valve several times no change. I then hooked the line from the vacuum pump directly to the metal line going to the modulator. Now the truck shifts fine. Will it do damage to the tranmission if I leave it this way? And also can the VCV be taken apart and rebuilt. I am sorry if I am bringing up a subject that has already been covered. But if someone could direct me in the right direction i will go from there. Thank you.
