NY 1986 Chevy M1009 K5 Blazer. Customized.
meat58
Spencer, NY
1986 Chevy M1009 K5 Blazer Customized, 65K miles on the 379CI Detroit Diesel engine. GM8 Turbo installed with air to water inter-cooler. The turbo and aggressive 4:10 gears gets this beast up to 85mph. Converted to 4 wheel disc brakes with new pads and rotors it stops on a dime. Dana 60 1 ton front axle, GM 14 Bolt 1 ton rear axle. 4:10 gears. Rebuilt Muncie SM465 Manual 4 speed transmission. Indestructible New Process (NP) 205 solid gear drive transfer case. Custom made drive shaft. Electric solenoid fuel pump, pushing 10 lbs exactly, makes cold starting easy. Hybrid diesel fuel injector pump can run thinner fuels. New 1000CCA battery. New water pump. Low speed stator alternator. HMMV 12 bolt wheels. 33 inch Goodyear All terrain tires. New Soft Topper khaki vinyl top. Floors replaced with aluminum diamond plate throughout. New front inner and outer fenders. New door sills welded in. New door skins, pickup truck tailgate. New front grill. New windshield. Cordura Jump seats in the back. Plush front seats with Cordura seat covers. This truck is a real head turner and a blast to drive on or off-road! 10 years of work and sourcing hard to find parts make the asking price $18,000. The DoD paid General Motors $30,000 for these in '86 with wimpier specs. You could drive this everyday!
