1987 M998 Fuel Pump Help
randy803
South Carolina
1987 M998 Cargo\troop Humvee
Guys I have a strange issue. 2 months ago my Mechanical Fuel pump went out (the one mounted to the block to provide fuel to the injector pump). I ordered one from Ebay for like $27;00 and replaced it. Everything was fine and then last week no fuel again. I assumed it was because I purchased a cheap chinesiam pump. I found a NOS Military pump and ordered it to replace again. The interesting thing is when I pulled the pump off it was FULL of red oil. I have been adding Marvel Mystery oil to the tank on each fill up. Why in the world would the Marvel Mystery oil pool up in the mechanical fuel pump? I have not added an excess! Is it bad to run the Marvel oil in the Humvee? Maybe that is what killed the first OEM pump? Any ideas?
randy803
South Carolina
No it is THICKER than fuel, like transmission fluid consistency. Really strange, has me shaking my head. How in the world could trans fluid get into the mechanical fuel pump? The known vampire effect would not effect the fuel pump right? Just the transfer case and hubs right?
Milcommoguy
2,402
Rosamond, CA
You might just have the diesel bug if it is gooo ie. Maybe or not. Keep an open mind. See my posts to what might be the problem. Search others too.
This could be a very sticky mess, CAMO
Mogman
10,496
Papalote, TX
Did the red fluid come out of the vent side or diesel side of the pump?
You should check the transfer case first to see if it is over full, you should also check the diffs and hubs, it does sound like you are pumping trans fluid into the vent system, via an over full transfer case.
86humv
543
Texas
Algae in fuel looks some what red.....if it is...its in everything and must be cleaned out....tank to Inj. pump.
