TN 1994 Stewart & Stevenson M1079 ~ Only 1,130 Miles ~ $25,000
Survivor180
Bristol, Tennessee
If you’ve been looking for a nice M1079 to build your overland camper, look no further. Very low mileage at only 1,130 miles. Starts, runs, and drives with no mechanical issues. No fluid leaks or air leaks. The only known issue is the CTIS is currently not working. It was not working when I bought the truck and I have not taken time to troubleshoot the problem. The air system is tight and works as it should but when the CTIS controller is powered, it doesn’t maintain pressure properly. This truck already has a 5.5 kw diesel generator mounted below the box and an air conditioner installed in the rear box area. The truck is stock aside of the installation of the generator, air conditioner, and floor covering in the box area. I had high hopes to build out the box as a camper but have not had the time and hate to see it sit when someone else could be enjoying the truck. $25,000IMG_1537.jpegIMG_1545.jpegIMG_1542.jpegIMG_1551.jpegIMG_1556.jpegIMG_1555.jpegIMG_1557.jpegIMG_1558.jpegIMG_1559.jpegIMG_1561.jpegIMG_1573.jpegIMG_1574.jpegIMG_1577.jpegIMG_1619.jpegIMG_1625.jpegIMG_1568.jpegIMG_1594.jpegIMG_1595.jpegIMG_1596.jpegIMG_1597.jpeg
