1998 LMTV Hot transmission - No drive
Ronmar
8,401
Port angeles wa
The trans goes out thru the bottom. Go to the manuals section from the steel soldiers main page, present conflict vehicles lmtv you will find all the M1078 manuals loaded by Ptracy. I think it is the -34.1 or -34.2 manual that has the trans removal procedure. There are also plans in the manual for building a lifting fixture y0u can build and bolt to the trans that will allow you to pick/suspend the trans from a single point above its center of gravity.
lay it down on a pallet or board and slide it out. Or lower it into a hole and roll the truck over it…
