1st EUC question
Smokinyoda
Franklin, NC
Every block MUST have an entry. If necessary, insert 'NONE,' 'SAME AS BLOCK X' or 'NOT APPLICABLE'
Filliing out my first EUC and I thought I was to leave no empty blanks. Section II, question 1c - I check the box, but dont write anything in blank? Just want to make sure before I submit, I want no delays.
GM72K10
66
Bucks County, Pa.
C. The property will not be sold or otherwise disposed of for use outside of the U.S. etc
I've always just checked the box to "agree"
41cl8m5
36
Littleton, CO
my first one I did not leave blank, was told though the GL site and email my FU. The person at GL was very informitive as to getting it right. The only thing you get no additional time to fix. Must be submitted correctly by the origainal time line. I got it done just in time > I rate that on the pucker scale (1-10) at a 11
swbradley1
Modertator
1,707
Dayton, OH
I haven't done one in a few months but if you just do a mouseover the field doesn't it tell you what to put in each one?
Yep, I just confirmed it.
It is helpful.
sw
