hot rod deuce
- 0
- 0
- Kasota, Mn
howdy, does any one know if you can swap a Ball CV type front u joint with the actual U joint type or even if the u joint is tougher like the magazine says?. I took my spare apart and found balls rolling all over the floor even as much as i hoped not to.
The plan is to ditch the short shaft and swap in a long one to widen it for the rear to match the width of the box and add stability.
