coolrides
- 0
- 0
- Deltona Fl
I'm having a problem with my steering axle (rockwell 2.5). the front end wobbles while driving down any road smooth or rough.
I jacked up the front of the truck and used a 6' pry bar to lift each tire looking for loose bearings what I found was a huge amount of play coming from the king pins. I bought the axle used and checked it out before installing it. the king pin bushings needed to be replaced and the king pins had a little wear (not enough to concern me at the time). after lees than 50 miles we are having all kinds of problems. did I miss something? was I supposed to shim the bushings? if the king pins are worn to the piont of needing to be replaced what can I do?
any help is appreciated.
