2.5 ton injection pumps
6x6junkie
p.a.
hello i have a deuce turbo multi will a non turbo injection pump work on it. or will a 5 ton pump work aswell are they all interchanjeable ? just as long as i time them right thanks
Westech
CPL
6,104
208
cow farts, Wisconsin
yes you can install a 5 ton pump BUT REMEMBER the 5 ton pump will have a higher fuel rate and you may need to tinker with that and the governor is set at 28/2900 RPM and not 2600 like the 2.5 ton pumps. This may cause a problem if your muliti is not tuned up VERY well and in good working order. I installed a 5 ton pump in my Deuce years ago and never had a problem running at 2900 RPM all day and night. But if yours is not in good shape.. you could be asking for it.
