2 bridge trucks in scrap iron yard
bigjuice69
sheyenne, north dakota
went down to the local scrap yard there sat 2 5on bridge trucks and a m35a2. going to get some parts next week if anybody needs some big parts call me 701-302-0224 kurt. ps:got them to hold off shearing them up for 2 weeks
monkster
Mt.Vernon, IN
LIghts, gauges, taillight s. If I rember the bridge trk had rear winches as well, this would mean the pto has got frt and rear shafts. Those are in demand. I am puting together a dump trk and payed to much for the pto w/ the rear shaft. Wish I was closer would help if needed
m139h2otruck
NH
Can we assume that these are M812s? If so, the PTO is a two way unit, front runs the front winch w/ two speeds and the rear runs the hydro pump for the a-frame and rear winch.
The rear axles are wider than standard M54/M800 style trucks, and the wheels are 10" wide but have deep offsets.
1,806
I'd sure be interested in the flood light mount assy's between the bed and the cab if they are there.
hndrsonj
Senior Chief/Moderator
361
Cheyenne, WY
If they have the multi engines, I would be interested in both power steering pumps.:smile:
DMgunn
SE North Dakota
Hey Kurt - I could use a pintle hitch - don't need the mount - just the hitch - and you may want to grab the t-cases if they are going for scrap prices - they tend to have dry bearing failure issues apparently.
Do these have hard tops?
bigjuice69
I am from Sheyenne between Jamestown and Devils Lake. Last spring i got a tranny, t-case, front diff, front springs, front and rear winches and some drive shaft parts. I have 84 and 86 1008, M51 dump, M945 getting bobbed and lube and service trailer.
hndrsonj
361
Cheyenne, WY
CSI in Talapoosa GA has several dozen bridge trucks in various disarray. You could call them if ODdave can't get them!
