2 man bulkhead?
Mogman
10,426
Papalote, TX
So I picked up a 2 man bulkhead and it looks like it will prevent the removal of the rear seat backs that are now used to cover the openings to the passenger foot wells?
It seems I will need to install access doors or remove the "half doors" to gain access.....Yes?
osteo16
596
Evansville, IN
I believe when I first picked mine up, I was able to remove seat backs from their stored position with a little wiggling.. It was a 2 man config with partition. Half doors would improve access under there of course..
TNDRIVER
568
Cleveland,TN
Got both, no problem. Remove the quarter turns, slide the back forward slightly, pick up the rear, slide out.
mgFray
992
Southern Minnesota
Same, hardest part is getting my hand in there is turn them.. often times I will use a screw driver under the bulkhead to do the quarter turn.. then it just slides out.
  • Like
Reactions: OBX
