2 questions on our M916A1
MuleMac01
Military vehicle collector
158
Las Vegas Nevada
Hi guys I have 2 questions about our M916A1
Frist off our PTO high idle for the drum winch doesn't work
What should I check?
Second what does this air regulator do in picture?
It's on top of the transmission was leaking air.
fasttruck
632
Mesa, AZ
If your truck has the 16 speed caterpillar transmission it could be there to cut the brake line pressure back to a lower value required by the transmission. The cat is an air shift unit and roadrangers which also use air for the range change function have such a pressure reducer.
MuleMac01
158
Las Vegas Nevada
No it has the Allison transmission.
