20,000# Garwood Winch seal kit
Neophyte
Gentlemen,
With my winch off the truck, I figured this would be a great time to re-seal the hydraulic motor and adapter (as the current seals disintegrated when removing them from the winch). Does anyone know where I could source these? Possible rebuild/refurbish kit?
Thank you
simp5782
Feo, Fuerte y Formal
9,327
Mason, TN
Adding this to this thread even though it is a little late for the OP.
# 50 pictured - Front Gasket - NSN 5330-00-895-3424- Same for 809/939 trucks - Found on ebay using that NSN
# 63 pictured - Side Gasket - NSN 5330-00-740-9821- Big Mikes motor pool stocks it under that NSN. Check google search.
# 60 pictured - Input seal gasket - NSN 5330-00-057-3823 - Same for 809/939 trucks - Found on ebay using that NSN
# 14 pictured - Encased Seal - NSN 5330-00-866-6236 - Found on ebay using that NSN.
# 41 pictured - Winch Drum Seal - NSN 5330-01-126-3469 - Found on ebay and surplus dealers using that NSN
# 59 pictured - Winch Input Seal - NSN 5330-01-150-9691 - Same for 809/939 trucks - Big Mikes motor pool and Found on ebay using that NSN.
Google search those NSN numbers and you will find suppliers. That is every seal and gasket in the TM exploded view the winch shows.
