2003 m1078a1 3126 275hp part missing next to cold starting aid canister
Suprman
654
Stratford/Connecticut
Prevents someone from putting the batteries in backwards. If your truck has batt cutoff solenoids at the batt box then your truck uses the advanced polarity box it assists in regulating battery charging.
everclimb
IL
My truck does have battery cutoff solenoids in a box next to the battery box. Does that mean I need something other than the n2003?
Leob
Guam
Hi suprman. Do you have the load cutoff relay that goes in between the battery cutoff and the LBCD?
