2007 MEP-806B no-start
robertsears1
119
Near Apex/NC
I would second checking the magnetic pickup. I have a MEP 804a that ran fine and all of a sudden it would not start, it would crank fine but it acted like it wasn’t getting fuel. Following the troubleshooting guide, I primed the snot out of it and nothing. Guyfang suggested checking the Magnetic Pickup and that was the problem—it had a piece of metal on the end. Cleaned and reset it and it cranked fine. The troubleshooting guide did not mention the MPU until further down the road—I suggest checking that first since it controls the fuel.
Robert
Guyfang
26,865
Burgkunstadt, Germany
So did you check the magnetic pick up, which is what controls the electronic actuator on top of the IP? Because that is what 9 times out of 10, is the problem. I sat next to this computer for 2 hours the other day, in the hope that you would answer. After all, we both posted at approximately the same time. 19:45 my time.
You don't have to call John Deere. After all, this is NOT an engine problem. John Deere doesn't use a Electronic Actuator. And John Deere can not help you with it without looking at the Military manuals. And guessing a bunch. If your still willing to give it a shot, then lets go!
Why didn't you write before Now. January. We could have had this fixed before now. So let do it.
