200amp alt question.... first of many to come
coachgeo
3,553
North of Cincy OH
going to install hummer 200amp alt in my LMTV (200AMP 14/28 DUAL VOLTAGE; Niehoff ; N1225-1 1244710).
general question... what is the amperage output split? 100 amp for each 14 and 28 (50/50 split)?? orrr varies on demand with max 50/50 or is it 60/40 orrr is amp output not limited to either side and whatever has highest draw just leaves the remaining potential left for the other ???? or am I totally confudled and looking at this entirely wrong.
PS- yes searched.. did not find answer but would be happy to search more if anyone can throw out potential keywords to search by and I'll try again.
Coug
4,841
Olympia/WA
200 amps of 24v and 50 amps of 12V is what the HMMWV 200 amp alt will put out to my understanding.
mechanicjim
40
Chicago il
see page 2 description of operation in the N1225 TG https://www.ceniehoff.com/Documents/Ctrl_Hyperlink/TG0017B_uid882013200562.pdf
so 200 28v no 14v load and less than 200 28v with 50A of 14v(basically the 14v robs the 28V side)
as a note the 12v/14v taps the come out of the regulator their made to handle 50 amps but can output a little more BUT they will overheat if you put too much load on them. so make sure you don't have too many 12v/14v loads on there
charlesrg
95
Nj
Did you ended up installing the 200A alternator ? I'm on the same page as you looking to use it to charge my LIFEPO4 bank while driving as a backup for days with no sun.
