208 lost 4-LOW
kraut83
virginia
I had a similar issue, mine also wouldn't stay in N, If I recall correctly there is a bolt that adjusts the shifter. If it is too far adjusted in either directions it can cause issues with shifting into 4wd and neutral. As long as nothing is missing simply adjust until it shifts like it should.
LT67
501
Bowdon, GA
Both of my m1008's will go into 4high real easy. 4low I have to shut off the engine to get it to go. If I don't shut off the engine, sounds like gears not meshing... is that a shifter adjustment?
cucvrus
10,427
Jonestown Pennsylvania
Put the transmission in neutral and it will shift right in with one smooth movement of the shifter. No need to turn the engine off. Just shift it with a smooth one movement shift when the transmission is in neutral. All is well. Good Luck.
LT67
501
Bowdon, GA
It should shift fine if you put it in neutral first.
Apologies for not making it clear; I put the trans in nuetral, move the lever all the way over to the right and it still will not go into 4low unless I shut off the engine.
